Hi, i have problem with my config. I try add ssl/tls support and i broke config file. Now postfix dont let me send any mail with error
warning: SASL authentication failure: Password verification failed
warning: SASL PLAIN authentication failed: authentication failure
warning: SASL LOGIN authentication failed: authentication failure
This may be a SASL configuration problem, rather than a Postfix issue (though the fact that it happened after a configuration change could indicate it is Postfix, though I don’t see any problems in a cursory glance at your config).
As for re-installing, that’s really trick on some distros (Debian/Ubuntu, because of the way dependencies work), and probably not recommended on any distro. It’s surely something minor, so let’s just track down what’s wrong and fix it.
So, find your sasl configuration file (if you tell me your distro/version, I can give you the exact path to it) and check for:
ubuntu 16.04 here. i suspect the issue is with the recent clam update. ive got a mail.log full of “CLAMAV: couldn’t connect to: /var/run/clamav/clamd.ctl: no such file or directory”
