Hello to everyone,
Let’s start saying that i’m investigating the problem as newbie.
I setup a virtualmin vps unmanaged host with two domain. One is still not configure, the other hosts magento cart.
I moved from a shared hosting where everything was working. Magento is working perfectly, just i’m not receiving email from my customer through the contact us module. I get positive sent and all the emails end in var/spool/mail/root without reaching the real email box hosted on google apps (dns are still on the old hosting). In the log: test.com is the domain, prs the main user for it. any ideas? both postfix and sendmail do the same…
Dec 5 16:27:36 prs sendmail[9808]: alias database /etc/aliases rebuilt by Diego
Dec 5 16:27:36 prs sendmail[9808]: /etc/aliases: 76 aliases, longest 10 bytes, 765 bytes total
Dec 5 16:27:36 prs postfix/postfix-script[9877]: starting the Postfix mail system
Dec 5 16:27:36 prs postfix/master[9878]: daemon started -- version 2.6.6, configuration /etc/postfix
Dec 5 16:27:45 prs sendmail[9910]: qB5DRjc2009910: from=prs, size=471, class=0, nrcpts=1, msgid=<201212051327.qB5DRjc2009910@test.com>, relay=prs@localhost
Dec 5 16:27:45 prs postfix/smtpd[9911]: connect from localhost.localdomain[127.0.0.1]
Dec 5 16:27:45 prs postfix/smtpd[9911]: 9A2DD1821DF0: client=localhost.localdomain[127.0.0.1]
Dec 5 16:27:45 prs postfix/cleanup[9914]: 9A2DD1821DF0: message-id=<201212051327.qB5DRjc2009910@test.com>
Dec 5 16:27:45 prs sendmail[9910]: qB5DRjc2009910: to==?utf-8?B?c3VwcG9ydA==?= , ctladdr=prs (505/505), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30471, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (Ok: queued as 9A2DD1821DF0)
Dec 5 16:27:45 prs postfix/qmgr[9881]: 9A2DD1821DF0: from=, size=887, nrcpt=1 (queue active)
Dec 5 16:27:45 prs postfix/smtpd[9911]: disconnect from localhost.localdomain[127.0.0.1]
Dec 5 16:27:45 prs postfix/local[9915]: 9A2DD1821DF0: to=, orig_to=, relay=local, delay=0.07, delays=0.06/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Dec 5 16:27:45 prs postfix/qmgr[9881]: 9A2DD1821DF0: removed
