postfix issue
wow! thanks for that :slight_smile: you must of also changed a few things as even emails sent from my website come from the right address now :smiley:
thank you so much
the reason those clamav things have been sitting there may be because i forgot i had disabled those services aswel
Removing those myorigin/myhostname/etc. bits would allow things to work correctly. To quote Cheap Trick again, "Everything works if you let it." :wink:
  1. it isnt writing anything to that file at all
  2. ns4.webtastix.co.nz
  3. 127.0.0.1 59509 localhost localhost.localdomain
    67.223.238.172 mailhost.webtastix.co.nz
    67.223.238.201 ns4.webtastix.co.nz
See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = ns4.webtastix.co.nz
relayhost = 67.223.238.172
mynetworks = 127.0.0.0/8
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = 67.223.238.173 67.223.238.201
home_mailbox = Maildir/
smtpd_sasl_auth_enable = yes
fork_attempts = 2
mydestination = mbcis.org ns4.webtastix.co.nz
mydomain = ns4.webtastix.co.nz
is /etc/mailname.
biff = no
TLS parameters
smtpd_use_tls=yes
fork_attempts = 2
attached is the master.cf file if thats any help
Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: "man 5 master").
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
67.223.238.201:smtp inet n - - - - smtpd -o smtpd_sasl_auth_enable=yes
67.223.238.173:smtp inet n - - - - smtpd -o smtpd_sasl_auth_enable=yes
#submission inet n - - - - smtpd
-o smtpd_enforce_tls=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
#smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - - 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
smtp unix - - n - - smtp
When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - n - - smtp
-o fallback_relay=
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
-o fallback_relay=
${nexthop} ${user}
