Just noticed the following errors in postfix on a centos 7 machine. How do I fix them?
[root@ns1 ~]# postfix check
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
[root@ns1 ~]# postfix status
postfix/postfix-script: the Postfix mail system is running: PID: 5945
[root@ns1 ~]#
OS type and version
CentOS 7
Webmin version
REQUIRED
Virtualmin version
REQUIRED
Related packages
SUGGESTED
Joe
February 17, 2022, 7:53pm
2
You’ve modified master.cf to add those…so, undo that change.
If you want us to help figure out what to change, you’ll need to post your master.cf
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master").
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
#smtp inet n - n - 1 postscreen
#smtpd pass - - n - - smtpd
#dnsblog unix - - n - 0 dnsblog
#tlsproxy unix - - n - 0 tlsproxy
#submission inet n - n - - smtpd
# -o syslog_name=postfix/submission
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_reject_unlisted_recipient=no
# -o smtpd_client_restrictions=$mua_client_restrictions
# -o smtpd_helo_restrictions=$mua_helo_restrictions
# -o smtpd_sender_restrictions=$mua_sender_restrictions
# -o smtpd_recipient_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
smtps inet n - n - - smtpd -o syslog_name=postfix/smtps -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes -o smtpd_reject_unlisted_recipient=no -o smtpd_client_restrictions=$mua_client_restrictions -o smtpd_helo_restrictions=$mua_helo_restrictions -o smtpd_sender_restrictions=$mua_sender_restrictions -o smtpd_recipient_restrictions=permit_sasl_authenticated,reject -o milter_macro_daemon_name=ORIGINATING
#628 inet n - n - - qmqpd
pickup unix n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
relay unix - - n - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
# flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
# flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
#ifmail unix - n n - - pipe
# flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
# flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
# flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
# ${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
# flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
submission inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
Joe
February 17, 2022, 10:37pm
4
So, that smtps line is different from what the Virtualmin installer sets up. Not sure how you got there.
I believe our default looks like this (though I only have quite old mail servers at the moment to look at, and it’s possible our defaults have changed in some small way since they were installed, I dunno):
smtps inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may -o smtpd_tls_wrappermode=yes
The line you have is normally in the file, but commented out, on a fresh CentOS 7 install (and we leave it commented out and just add ours during the virtualmin-config stage of installation.
I see the submission line, which I think we also add, so I don’t know how you got where you are. If you didn’t have any of our config, I would assume install didn’t complete (Postfix is one of the last configs to get modified, so it may have looked pretty normal all the way until toward the end…still would have been a red X, or at least it would have bailed before all items completed). But, since you have some of it, I assume it’s just been changed since install to remove our line and uncomment the original line. You’ll have to figure out why/when, I guess. This isn’t a security sensitive change, so I can’t imagine it’s indicative of anything dangerous…but, somebody changed it, so kinda weird, if you don’t know why it’s been changed.
system
Closed
April 18, 2022, 10:37pm
5
