Postfix authentication problem
Hi all,
I cannot let my users work with postfix smtp with authentication.
I’ve read all the docs:
  • settings on the server templates are ok for using user@domain form
  • server template has email services enable
  • account template has unlimited email account
Anyway, I can use POP3/IMAP services but not the SMTP.
It appears as the domain is truncated:
authenticating as test@prova.com the saslauthd log reports that the user authenticating is test.com
What’s wrong?
What output do you see if you run this command:
ps auxw | grep saslauth
I forgot to say that the saslauth has the “-r” flag.
root 15312 1 0 08:12 ? 00:00:00 /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5 root 15313 15312 0 08:12 ? 00:00:00 /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5 root 15315 15312 0 08:12 ? 00:00:00 /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5 root 15316 15312 0 08:12 ? 00:00:00 /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5 root 15317 15312 0 08:12 ? 00:00:00 /usr/sbin/saslauthd -a pam -m /var/spool/postfix/var/run/saslauthd -r -n 5
None?
