It’s true I am a newbie with a problem (off course).
Could you help me … please.
I have problems downloading my e-mails (POP3) in Virtualmin. The only way I can download them is to use a SSL connection. I’ve been googling for some time but I can’t find a solution for my problem. For security reasons that would be okay.
you may want to check webmin - servers - postfix server - SMTP Authentication And Encryption - Enable TLS encryption? set to never or If requested by client.
see if that helps
I tried it. I want to test oulook as a mailclient. I think maybe somthing is wrong with the username.
If I use the Imap/FTP ID and SSL i can download. If I use the Imap/FTP ID without SSL outlook asks me for logindata. I thought login would for POP3 would be user.domain
