Please Help ! I have installed Lets Encrypt SSL certificate on my domain using usual Virtualmin Lets Encrypt Panel. SSL certificate is Installed correctly, No errors shown in Virtualmin Panel.
But When I check the domain using https://sslshopper.com, I am getting this error:
The certificate is not trusted in all web browsers. You may need to install an Intermediate/chain certificate to link it to a trusted root certificate. Learn more about this error. The fastest way to fix this problem is to contact your SSL provider.
GT metrix is also showing same error .
Anybody Knows, What is the Problem?
