Getting the FQDN to work properly can be a b*tch.
Basically, for the FQDN resolution to work correctly, three (or four) things need to play together. That’s the files /etc/hostname, /etc/hosts, /etc/resolv.conf and your external nameserver (provided by your hoster e.g.).
Let’s say your server’s hostname is “lyra” and its already established and externally resolvable domain name is “tianet.de”. Let’s further say that lyra’s IP is 46.4.181.243, and the nameserver that forwards requests to the outside has the IP 46.4.181.241 (real-life example from my experimental Virtualmin VM).
Then the contents need to be as follows:
/etc/hostname
lyra
/etc/hosts
127.0.0.1 localhost
46.4.181.243 lyra.tianet.de lyra
(Note that I have both the FQDN and the standalone hostname there.)
/etc/resolv.conf
nameserver 46.4.181.241
domain tianet.de
After setting these contents, it might be helpful/required to reboot the machine or execute /etc/init.d/networking restart
, though usually that’s not necessary.
hostname
should then reply with “lyra”, and hostname -f
with “lyra.tianet.de”.
If you still have trouble then, you can additionally check the file /etc/nsswitch.conf
which tells the system which facilities to consult for resolving various stuff. You should have a line like this there:
hosts: files dns
If it’s missing or deviating, edit it to this.
Note that later, as soon as Virtualmin installs BIND, the following line will/must get added to the top of resolv.conf
, so that your locally hosted domains resolve directly:
nameserver 127.0.0.1
