Hi I have install phpmyadmin using the provided plugin in Webmin, but when I got to the url it does not load?
You can describe the showed error if there is any ?
Common checks
- Check DNS, try to resolve that website, it matches with the VirtualMin IP ?
dig domain.com
- Check if there is any
.htaccess
file in that folder that can cause problemes getting that folder - Reinstall phpmyadmin, check if the final resume is correct and it generate all the URL
You can try…
- Force your system to resolve that domain with VirtualMin IP, that will ignore all DNS resolutions
vim /etc/hosts
Add at the end of the file
IP_virtualMinHost www.domain.com domain.com
