I’m having same issue tring to install phpBB 3.0.1
Found http://jaist.dl.sourceforge.net:80/sourceforge/phpbb/phpBB-3.0.1.zip in cache …
Now installing phpBB version 3.0.1 …
phpBB database configuration failed
More information on using this script can be found at http://www.phpbb.com/.
… installation was only partially complete.
Configuring Apache PHP settings …
… already done.
I’m riding on this post to see if you added it to the tracker; I couldn’t find it doing a search; but didn’t want to add it if it already existed.
Just to let you know my issue turned out to be a mistake I made earlier by adding Joomla to a folder and not the Top level; then after I realized my mistake I uninstalled the Joomla Script and reinstalled it in the Top Level; doing a Validate Virtual Server Under Limits and Validation; gave an error folder joomla not found; I had to back up the Virtual Server and delete it and reinstall it to fix this; I think this needs to be fixed; it might be a bug; I did some searching and asked that question a few times and got no answer; but anyway after that it installed fine.
