I updated the PHP version from the Bleeding Edge Package Repositories.
After that i noticed that I am getting strange problems in PHP-XML files
like: Error loading XML document!
I usually use a open source tool PHPSYSINFO.
When i upload the contents of that software which uses xml document is gives error outut as:Error loading XML document!
Yeah, newer PHP versions handle some things differently than the version that comes with CentOS.
One way to handle that is that those problems often go away when using mod_php as your PHP execution mode (which you can set in Server Configuration -> Website Options).
Other folks have said their apps didn’t work until after they set “cgi.fix_pathinfo=0” in the $HOME/etc/php.ini file.
