Basically I have a php script in a sub server (sub domain), and I upload a php script and try to run it but it doesn’t run? It just shows me the php code, how to fix that? Thanks!
If you go into Server Configuration -> Website Options for that Sub Server, what is the PHP Execution Mode set to?
PHP Script execution mode is set to : Apache mod_php (run as Apache’s user)
What if you set it to FCGI or CGI, do PHP scripts begin to work as expected at that point?
If I set it to CGI wrapper, it loads slow but works. If I set it to FGCId, it loads fast and well.
(My main domain is auto-set to FGCId, does that explain it?)
Ah, yeah, it sounds like the Sub-Server Template may be configured to set new Sub-Servers to “mod_php”.
To correct that for new domains, go into System Settings -> Server Templates -> Settings for Sub-Servers -> Apache Website, and there, make sure “Default PHP execution mode” is set to FCGID.
