I have in every account in Virtuemart Fast CGI
I Re-Check Configuration
I am going to Virtuamin(user) --> Server Configuration --> PHP Versions --> change the version from 5.4 to 5.6 or 7
When i save there is no error and i see that the Version is the one i chose now
But i still if i login via ssh as root or as the user, go to user directory and run:
php -v or run a .php file with phpinfo();
i see php 5.4
but still not for the user directories,
from System Settings -> Re-Check Configuration i get the following
The following PHP versions are available : 5.4.16 (/bin/php-cgi), 5.6.25 (/opt/rh/php56/root/usr/bin/php-cgi), 7.0.10 (/opt/rh/rh-php70/root/usr/bin/php-cgi), 5.4 (mod_php)
so it’s getting detected but why it is not working?
That probably indicates you’re using mod_php; versions are not switchable for mod_php…it’s always whatever version is enabled in Apache.
Don’t use mod_php, as it’s a bad idea on many fronts (security, memory usage, performance, etc. are all worse with mod_php). Use either mod_fcgid or PHP-FPM execution mode. PHP-FPM should be the default in a fresh installation, but it can be changed on a per-domain basis.
*"i managed to change the php version for the root user with the command
scl enable rh-php56 bash"*
As you noticed, this doesn’t actually do anything. It only affects the current path for the logged in user (and only for the current shell session). It has literally no impact on Apache or any user or any other things.
i fixed the issue, now i understand how webmin/virtuemin works
I selected the PHP from PHP VERSIONS and In front end the phpinfo file now shows the correct PHP version, after running:
systemctl restart httpd
Basically my main issue was the Composer, i was trying to install packages and it was saying that my PHP is not compatible >=PHP56
so i found out that you can change the php for the current SSH session as i mentioned before by running this command
and it worked but php extensions was missing so i tried to update them via ssh and all the extensions was up to date.
then i stuck for a while and i found out that i could install them via software packages.
Webmin > System Software Packages > Choose Package from YUM > Click Browse YUM, type the php extension name in the search box and click find packing matching button, and then click the package name install.
then by running composer update/install
and it worked fine not extensions missing
PS*
at some point i run this command which points to alternate PHP
ln -s /opt/rh/rh-php56/ /opt/rh/php56
i don’t know if that did the trick for the Virtuemin PHP Versions
