My VM GPL is a fresh, untampered install of the latest version (except I turned off SELinux).
I cannot upload files through PHP. No error is generated in the httpd error_log, or messages, or dmesg nor is a message generated through PHPs error_reporting. It just doesn’t work.
I noticed the problem in Joomla first, but then wrote a little script to isolate the prob. After uploading, PHP returns true to file_exists() in the system /tmp dir, but there is nothing in there when I check form the command line.
I can’t see any of the usual suspects in PHP.ini. I am attaching it even though it’s virgin
What should I do to try and diagnose this? Or better yet, fix it? [file name=phpini.zip size=15272]http://www.virtualmin.com/components/com_fireboard/uploaded/files/phpini.zip[/file]
Post edited by: epimedia, at: 2008/09/03 02:35<br><br>Post edited by: epimedia, at: 2008/09/03 02:36
