SYSTEM INFORMATION | |
OS type and version | REQUIRED |
Webmin version | REQUIRED |
Virtualmin version | REQUIRED |
Related packages | SUGGESTED |
PHP execution mode fcgid was selected in the default template, but is not supported on this system, and now will be changed to none
The status of your system is being checked to ensure that all enabled features are available and properly configured …
Your system has 15.39 GiB of memory, which is at or above the Virtualmin recommended minimum of 256 MiB
BIND DNS server is installed
Mail server Postfix is installed and configured
Postfix is configured to support per-domain outgoing IP addresses
Apache is installed
Apache does not support HTTP/2 : Missing Apache mod_http2 module
The following PHP execution modes are available : fpm
The following PHP-FPM versions are available : 5.4.16 (php-fpm)
PHP versions have changed to 5 since last check. Regenerating any missing php.ini files
Apache is configured to host SSL websites
MariaDB 5.5.68 is installed and running
Logrotate is installed
SpamAssassin and Procmail are installed and configured for use
ClamAV is installed and running
Plugin AWStats reporting is installed
Plugin Protected web directories is installed
Using network interface eno1 for virtual IPs
Default IPv4 address for virtual servers is 49.38.78.7
Both user and group quotas are enabled for home and email directories
All commands needed to create and restore backups are installed
The selected package management and update systems are installed
Chroot jails are available
… your system is ready for use by Virtualmin
Updating all Webmin users with new settings…
… done
Updating status collection job …
… done
Re-loading Webmin …
… done
I can’t use PHP execution mode fcgid
