I’m running eAccelerator on my server, and it’s caching scripts for the virtual servers running PHP as apache under mod_php. However, for the sites/virtualservers running PHP as owner under FCGId, eAccelerator is not caching scripts.
I know it should work, I have seen several references to it being possible & optimal:
http://www.interworx.com/forums/showpost.php?p=8343&postcount=3
http://support.tigertech.net/fastcgi#3
Any advice on what I need to do to make it work.
Apparently if there is a version mismatch between the version of PHP eaccelerator was compiled for & the reported version, the scripts of fcgid enabled virtual servers will not be cached:
http://eaccelerator.net/ticket/252
versions:
eAccelerator 0.9.5.2 [shm:mmap_anon sem:fcntl]
PHP 5.1.6 [ZE 2.1.0]
Using apache2handler on Linux vacantserver.net 2.6.18-53.1.13.el5 #1 SMP Tue Feb 12 13:01:45 EST 2008 i686
