On a fresh install of Centos 7 (64) and Webmin/Virtualmin…
First I had to manually edit the global apache conf file, adding “SetHandler application/x-httpd-php” for php scripts to be executed on virtual servers. Is it normal, or could I fix it in the virtual server setup or config?
Now so php is working, but CSS files that are in php scripts are not executed at all, on virtual servers. I tried to edit the global Apache config file but it didn’t help, and anyway it looks a strange method!
Any suggestion? Thank you!
