hello
at first sorry for my english
is what C is possible to use command RPC with one to use Unix/webmin to create with virtualmin because I receive this message when J are of launching an order in RPC on webmin with another user that root ERROR: You are not allowed to run remote webmin and virtualmin generate permission in form ACL for the use J have are D to modify some but I am lost in the value has to put at it for example for the root.acl J have to find a value rpc=2 whereas for testuser.acl there is rpc=0 eme if I change this value no chance can be qu it is necessary to add something has miniserver.conf in the case or this N is not possible to make safe command RPC with lutilisator root as C east indicates in Doc. Even though has API command-line exists for managing Virtualmin objects such ace servers, users and databases, this may not Be appropriate but liable to wear out in all circumstances. Because the commands need to Be run ace root, D different leaves I would like to know how to use xml-RPC on webmin I N do not arrive has to me logger has traver http://yourserver:10000/xmlrpc.cgi same with root which is necessary it to change in the configuration webmin
thank you<br><br>Post edited by: operweb, at: 2009/03/08 09:24
I think you may be calling the wrong API … it looks like you are trying to use the Webmin XML-RPC API instead of the one for Virtualmin.
Can you tell me what you are trying to get Virtualmin to do via the API?
So you are trying to make xml-rpc calls to the Virtualmin API? At the moment, that is not possible … the only format it supports for requests is simple URL parameters, and responses are always in text format.
what can i do to allow other user than root or admin to run command remote
Do you mean via virtual-server/remote.cgi , or xmlrpc.cgi ?
The latter is controlled by the setting at Webmin -> Webmin Users -> username -> Permissions for all modules -> Can accept RPC calls?.
i hav all ready access to rpc command at remote.cgi with root access
i need to get enabled access to xml-rpc on xmlrpc.cgi with root and other user created with virtualmin account
cause i have this message when i try to login with root at https://server:10000/xmlrpc.cgi
[code:1]<methodResponse>
â
â
