I installed a freshly new Virtualmin with GPL license and upon a virtual host creation I’m getting the following error:
Performing other Apache configuration …
… configuration failed : Failed to copy /etc/php/7.0/cgi/php.ini to /home/domains/domain.com/etc/php7.0/php.ini : cp: preserving times for ‘/home/domains/domain.com/etc/php7.0/php.ini’: Operation not permitted
Setting up log file rotation …
… no logging directive found in webserver configuration!
Disk space maybe? I’ve never seen this kind of error. There’s multiple things going wrong here, and they’re pretty dramatic things; I’m guessing updating the web server configuration is failing, too, based on the logging config error.
Is /home on some weird filesystem? Like FAT or NTFS or something crazy like that that doesn’t have normal permissions and metadata? Maybe a network filesystem of some sort? You’d need something that supports UNIX filesystem semantics.
