Today while trying to run some updates on a VM Pro installation I got the package signing error detailed below. I don’t know why, I have done many updates in the past that have not had this effect. Ideas?
Dave
Update Packages
Now updating httpd …
Installing package(s) with command yum -y install httpd ..
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.its.sfu.ca
* extras: mirror.its.sfu.ca
* updates: mirror.its.sfu.ca
Setting up Install Process
Resolving Dependencies
--> Running transaction check
--> Processing Dependency: httpd = 1:2.2.3-43.3.vm for package: mod_ssl
---> Package httpd.x86_64 1:2.2.3-45.1.vm set to be updated
---> Package mod_ssl.x86_64 2:2.2.3-45.1.vm set to be updated
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
httpd x86_64 1:2.2.3-45.1.vm virtualmin 1.2 M
Updating for dependencies:
mod_ssl x86_64 2:2.2.3-45.1.vm virtualmin 93 k
Transaction Summary
Install 0 Package(s)
Upgrade 2 Package(s)
Total size: 1.3 M
Downloading Packages:
Package mod_ssl-2.2.3-45.1.vm.x86_64.rpm is not signed
.. install failed!
No packages were installed. Check the messages above for the cause of the error.
