Dear all,
I have enabled the OpenCart SEO setting but it cannot work. I can work on Cpanel automatically. Do there any configuration that required to do inside Webmin and Virtualmin?
Dear all,
Are you running apache or nginx?
Try checking this out.
Apache
You have mod rewrite installed and have renamed htaccess.text?
If you have done that an sorted setting in opencart i would have thought it should work.
Dear Sir,
How can I enable the mod rewrite? I followed another post:
“Easiest way if you are not too familiar with centos would be in: Webmin -> Servers -> Apache Webserver -> Global Configurations -> Configure Apache Modules. Just make sure Rewrite is ticked off and save.”
But I cannot find such path.
