Ongoing Email Problems
I’m having major Email issues and my hosting company doesn’t provide support. Initially there was a plain text authorisation issue which has been corrected. Now when I go to receive mail on the domain I get a 0X800CCC0E error and when I try to send mail the password is rejected. Is there still a permissions issue in the Postfix authentication system? If anyone can help it will be much appreciated, as I’m pulling my hair out on this one and at the stage where I’m going to recommend to my client that they transfer to a simple business hosting package. Thanks in advance.
I think we’ll need more information about this to give meaningful hints. :slight_smile:
First, are we talking about a Virtualmin system under your control which you are configuring? Your second sentence somewhat sounds like your hoster is configuring the stuff for you.
Where do you get an “0x800ccc0e error”? Please post precise circumstances what you tried and where you got what error. Log excerpts (please put them in tags if you post them here) often help too.
How do you try to send mail? From what application? Are you sure you’re using the correct username and password?
