On both server a new
CentOS 7.9.2009
Linux 3.10.0-1160.42.2.el7.x86_64 on x86_64
Webmin 1.981
Firewalld opened service DNS and ports 10000-10010 (also have stop firewalld on both for testing)
I’m following the document here by…
Added slave server via Webmin Server Index
The server appears in Cluster Slave Servers
Then I get " Server server is not running Webmin version 1.202 or above."
In my first attempt I was able to get my old CentOS 6 server to work with a newly built system, but not the third. The one I could setup as slave could connect with the third server but not the other way around. I scratched all of that and created two new machines to start from scratch so I could my old nameservers up to prevent DNS issues. This really through me for a loop why some work and some don’t, thus two fresh clean systems.
Here I don’t see the port or ndmp change to webmin (something like that when I monitored a good connection)
TCPDUMP
15:04:11.004460 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [S], seq 4133328205, win 29200, options [mss 1460,sackOK,TS val 4855092 ecr 0,nop,wscale 7], length 0
15:04:11.004963 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 907491861, win 229, options [nop,nop,TS val 4855093 ecr 6043217], length 0
15:04:11.007109 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [P.], seq 0:321, ack 1, win 229, options [nop,nop,TS val 4855095 ecr 6043217], length 321
15:04:11.019751 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 1041, win 245, options [nop,nop,TS val 4855107 ecr 6043222], length 0
15:04:11.020264 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [P.], seq 321:639, ack 1041, win 245, options [nop,nop,TS val 4855108 ecr 6043222], length 318
15:04:11.024614 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [P.], seq 639:696, ack 1283, win 261, options [nop,nop,TS val 4855112 ecr 6043237], length 57
15:04:11.065020 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [P.], seq 696:1118, ack 1283, win 261, options [nop,nop,TS val 4855153 ecr 6043278], length 422
15:04:13.280794 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 2876, win 300, options [nop,nop,TS val 4857369 ecr 6045484], length 0
15:04:13.280893 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 7220, win 368, options [nop,nop,TS val 4857369 ecr 6045487], length 0
15:04:13.281002 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 14460, win 481, options [nop,nop,TS val 4857369 ecr 6045489], length 0
15:04:13.281300 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 20252, win 571, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.281330 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 24596, win 639, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.281348 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 30388, win 730, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.281470 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 33284, win 775, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.281482 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 37628, win 843, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.281674 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 43420, win 891, options [nop,nop,TS val 4857369 ecr 6045494], length 0
15:04:13.282259 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [S], seq 3986674864, win 29200, options [mss 1460,sackOK,TS val 4857370 ecr 0,nop,wscale 7], length 0
15:04:13.282649 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [.], ack 1154455559, win 229, options [nop,nop,TS val 4857370 ecr 6045495], length 0
15:04:13.288898 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [P.], seq 0:321, ack 1, win 229, options [nop,nop,TS val 4857377 ecr 6045495], length 321
15:04:13.291579 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [.], ack 1041, win 245, options [nop,nop,TS val 4857379 ecr 6045503], length 0
15:04:13.291995 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [P.], seq 321:639, ack 1041, win 245, options [nop,nop,TS val 4857380 ecr 6045503], length 318
15:04:13.298473 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [P.], seq 639:696, ack 1283, win 261, options [nop,nop,TS val 4857386 ecr 6045510], length 57
15:04:13.320778 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 81068, win 597, options [nop,nop,TS val 4857409 ecr 6045494], length 0
15:04:13.337880 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [P.], seq 696:1168, ack 1283, win 261, options [nop,nop,TS val 4857426 ecr 6045551], length 472
15:04:13.360726 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 131748, win 202, options [nop,nop,TS val 4857449 ecr 6045534], length 0
15:04:13.400820 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 149124, win 67, options [nop,nop,TS val 4857489 ecr 6045574], length 0
15:04:13.440898 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 154916, win 22, options [nop,nop,TS val 4857529 ecr 6045614], length 0
15:04:13.476362 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [.], ack 2804, win 284, options [nop,nop,TS val 4857564 ecr 6045689], length 0
15:04:13.477277 IP pri.nameserver.43964 > sec.nameserver.ndmp: Flags [R.], seq 1168, ack 4240, win 306, options [nop,nop,TS val 4857565 ecr 6045689], length 0
15:04:13.477329 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [S], seq 2815079211, win 29200, options [mss 1460,sackOK,TS val 4857565 ecr 0,nop,wscale 7], length 0
15:04:13.477661 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [.], ack 2965620687, win 229, options [nop,nop,TS val 4857566 ecr 6045690], length 0
15:04:13.477810 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [P.], seq 0:321, ack 1, win 229, options [nop,nop,TS val 4857566 ecr 6045690], length 321
15:04:13.480713 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 157732, win 0, options [nop,nop,TS val 4857569 ecr 6045654], length 0
15:04:13.482068 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [.], ack 1041, win 245, options [nop,nop,TS val 4857570 ecr 6045695], length 0
15:04:13.482449 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [P.], seq 321:639, ack 1041, win 245, options [nop,nop,TS val 4857570 ecr 6045695], length 318
15:04:13.486137 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [P.], seq 639:696, ack 1283, win 261, options [nop,nop,TS val 4857574 ecr 6045699], length 57
15:04:13.526115 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [P.], seq 696:1206, ack 1283, win 261, options [nop,nop,TS val 4857614 ecr 6045739], length 510
15:04:13.662405 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [.], ack 2804, win 284, options [nop,nop,TS val 4857750 ecr 6045875], length 0
15:04:13.663004 IP pri.nameserver.43966 > sec.nameserver.ndmp: Flags [R.], seq 1206, ack 4240, win 306, options [nop,nop,TS val 4857751 ecr 6045875], length 0
15:04:13.663178 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [S], seq 3160892343, win 29200, options [mss 1460,sackOK,TS val 4857751 ecr 0,nop,wscale 7], length 0
15:04:13.663580 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 1347215365, win 229, options [nop,nop,TS val 4857751 ecr 6045876], length 0
15:04:13.663739 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [P.], seq 0:321, ack 1, win 229, options [nop,nop,TS val 4857752 ecr 6045876], length 321
15:04:13.667550 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 1041, win 245, options [nop,nop,TS val 4857755 ecr 6045880], length 0
15:04:13.667970 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [P.], seq 321:639, ack 1041, win 245, options [nop,nop,TS val 4857756 ecr 6045880], length 318
15:04:13.671697 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [P.], seq 639:696, ack 1283, win 261, options [nop,nop,TS val 4857760 ecr 6045884], length 57
15:04:13.701953 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [.], ack 157732, win 0, options [nop,nop,TS val 4857790 ecr 6045654], length 0
15:04:13.711989 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [P.], seq 696:1186, ack 1283, win 261, options [nop,nop,TS val 4857800 ecr 6045925], length 490
15:04:13.846903 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 2804, win 284, options [nop,nop,TS val 4857935 ecr 6046059], length 0
15:04:13.850919 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 11480, win 419, options [nop,nop,TS val 4857939 ecr 6046060], length 0
15:04:13.851079 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 14376, win 465, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851098 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 17272, win 510, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851276 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 20168, win 555, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851301 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 24512, win 623, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851452 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 30304, win 714, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851476 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 33200, win 759, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851483 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 36096, win 804, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.851496 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [.], ack 41888, win 895, options [nop,nop,TS val 4857939 ecr 6046064], length 0
15:04:13.854865 IP pri.nameserver.43962 > sec.nameserver.ndmp: Flags [R.], seq 1118, ack 157732, win 933, options [nop,nop,TS val 4857943 ecr 6045654], length 0
15:04:13.854916 IP pri.nameserver.43968 > sec.nameserver.ndmp: Flags [R.], seq 1186, ack 95464, win 917, options [nop,nop,TS val 4857943 ecr 6046064], length 0
