the option to enable ssl for virtual server is not present. i have tried to follow instructions from old versions of virtualmin but it doesn’t seem to be an option anymore to enable SSL for virtual servers anymore.
-Sean
-Sean
only things that show up with enabled features are;
Mail for domain enabled?
Apache website enabled?
Webalizer reporting enabled?
Log file rotation enabled?
MySQL database enabled?
Webmin login enabled?
as i have turned off bind9 in virtualmin.
-Sean
Does the option show up if you log in as root? Is that just an issue for Virtual Server owners?
