$ sudo nmap 62.171.154.199
[sudo] password for joe:
Starting Nmap 7.93 ( https://nmap.org ) at 2023-05-06 12:54 CDT
Nmap scan report for vmi495036.contaboserver.net (62.171.154.199)
Host is up (0.16s latency).
Not shown: 990 filtered tcp ports (no-response)
PORT STATE SERVICE
22/tcp open ssh
25/tcp open smtp
80/tcp open http
110/tcp closed pop3
143/tcp closed imap
443/tcp open https
465/tcp open smtps
587/tcp open submission
993/tcp closed imaps
995/tcp closed pop3s
Nmap done: 1 IP address (1 host up) scanned in 10.35 seconds
Something at the network layer is not allowing port 10000.
Compre to, e.g., one of my systems:
$ sudo nmap www.virtualmin.com
Starting Nmap 7.93 ( https://nmap.org ) at 2023-05-06 12:55 CDT
Nmap scan report for www.virtualmin.com (45.76.57.243)
Host is up (0.028s latency).
Not shown: 847 closed tcp ports (reset), 135 filtered tcp ports (no-response), 7 filtered tcp ports (admin-prohibited)
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
25/tcp open smtp
53/tcp open domain
80/tcp open http
443/tcp open https
465/tcp open smtps
2222/tcp open EtherNetIP-1
3306/tcp open mysql
10000/tcp open snet-sensor-mgmt
Nmap done: 1 IP address (1 host up) scanned in 1.92 seconds
It listing loaded module in your kernel. net are networking modules, filter is a packet filter module usage and ipt, nft, and bpf is types of packet filters. From your dmesg I think you have a BPF packet filter used in the kernel. I want to make sure about it, because it is also a firewall. I see that you enjoy the virtual machine kvm. What frontend are you using? Or your provider. Proxmox? In proxmox kernel images is BPFILTER is often allowed and in installation used.
Command ‘table’ not found, but can be installed with:
snap install table
Command ‘filter’ not found, but can be installed with:
apt install filter
Command ‘bpf’’ not found, did you mean:
command ‘bpfc’ from deb netsniff-ng (0.6.5-1build1)
Try: apt install
Command ‘ipt’ not found, did you mean:
command ‘opt’ from deb llvm (1:10.0-50~exp1)
command ‘pt’ from deb tcllib (1.20+dfsg-1)
command ‘idt’ from deb ncl-ncarg (6.6.2-1build4)
command ‘iptc’ from deb libiptcdata-bin (1.0.5-2.1ubuntu4)
command ‘apt’ from deb apt (2.0.9)
command ‘dpt’ from deb pkg-perl-tools (0.59)
command ‘ipa’ from deb freeipa-client (4.8.6-1ubuntu2)
command ‘ppt’ from deb bsdgames (2.17-28build1)
command ‘iyt’ from deb python3-yt (3.5.1-3build1)
command ‘ips’ from deb ips (4.0-1build3)
command ‘ipbt’ from deb its-playback-time (0.2017-08-30.3c40fd3-1)
command ‘ip’ from deb iproute2 (5.5.0-1ubuntu1)
command ‘iat’ from deb iat (0.1.3-7build1)
command ‘gpt’ from deb gpt (1.1-5build1)
command ‘ipe’ from deb ipe (7.2.13-2build1)
No, you started it incorrectly. Do not install anything. They are two statements concatenated by a pipe. lsmod and egrep and “|” a pipe between them. lsmod list all modules and egrep select just expected.
Here is my output if I’am standard user:
ony@ares:~$ lsmod | egrep ‘net|filter|table|nft|ipt|bpf’
Command ‘nft’ is available in the following places
/sbin/nft
/usr/sbin/nft
The command could not be located because ‘/sbin:/usr/sbin’ is not included in the PATH environment variable.
This is most likely caused by the lack of administrative privileges associated with your user account.
nft: command not found
Try: sudo apt install
sudo snap install table
sudo apt install filter
root@k9sports:/# sudo lsmod | egrep ‘net|filter|table|nft|ipt|bpf’
nft: no command specified
snap install table
Try: apt install
Try: apt install
Or use: sudo su -
Test root account with command: whoami
Output from whoami must be: root
An after use command lsmod | egrep ‘net|filter|table|nft|ipt|bpf’
