I have just purchased the Pro version of Virtualmin for use on Amazon EC2 (under RightScale).
I was wondering if it was possible to prevent the installation script from prompting me for a yes/no confirmation during the install. I need the script to run automatically when I boot a new server, and so it will be detached from any console (and will therefore no proceed past the confirmation prompt).
Would it be possible to add a ‘–non-interactive’ parameter (or similar) to the install script as I think that this will be a problem for most people using EC2?
I’m unfortunately not particularly familiar with the EC2 installer. There are a few folks using EC2 though – if you’re still having troubles, I might recommend opening a support ticking using the Bugs/Issues link below, and Joe/Jamie may be able to offer some additional insight into how to get that working!
For the benefit of those that come this way in the near future, Jamie Cameron has resolved this issue and a fix will be present in the next release of the installer script (aparently you will need to set the ‘VIRTUALMIN_NONINTERACTIVE’ environment variable to ‘yes’).
In the mean time, the following works as a work around:
