First of all, my Operating system = CentOS Linux 7.7.1908 & Virtualmin version = 6.08.
Please, what I want to achieve is, have all mobile users redirected from www.example.com to subdomain: mobile.example.com.
I have setup the main domain which is www.example.com with the root as /home/user/public_html and also installed letsencrypt ssl and everything is working ok.
I created a subdomain: mobile.example.com in virtualmin, created an A record for it with Cloudflare’s proxy on and also changed its home directory from /home/user/domains/mobile.example.com to the main domain document root: /home/user/public_html.
And here is the nginx configuration for mobile.example.com:
server {
listen 80;
server_name mobile.example.com;
return 301 http://mobile.example.com$request_uri;
server {
listen 443 ssl http2;
root /home/user/public_html;
index index.html index.htm index.php
ssl_certificate /etc/letsencrypt/live/example.com/cert.pem;
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/example.com/chain.pem;
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
ssl_stapling on; # managed by Certbot
ssl_stapling_verify on; # managed by Certbot
# log files
access_log /var/log/virtualmin/mobile.example.com_access_log;
error_log /var/log/virtualmin/mobile.example.com_error_log;
location / {
try_files $uri $uri/ /index.php?$args;
# REQUIREMENTS : Enable PHP Support
location ~ \.php$ {
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_FILENAME
/home/user/public_html$fastcgi_script_name;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT /home/user/public_html;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param HTTPS $https;
location ~ \.php$ {
try_files $uri =404;
fastcgi_pass unix:/run/php-fpm/www.sock;
And then the nginx configuration for the main domain www.example.com is:
server {
listen 80;
server_name example.com www.example.com;
return 301 https://www.example.com$request_uri;
server {
server_name example.com;
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
ssl_trusted_certificate /etc/letsencrypt/live/example.com/chain.pem; # managed by Certbot
server {
server_name www.example.com;
index index.php;
# SSL parameters
ssl_client_certificate /etc/ssl/certs/origin-pull-ca.pem; # Cloudflare origin pull cert
ssl_verify_client on; # Cloudflare origin pull cert
add_header Content-Security-Policy upgrade-insecure-requests;
add_header Referrer-Policy 'strict-origin';
add_header Feature-Policy "vibrate none; geolocation none; unsized-media
https://www.example.com;";
add_header "Access-Control-Allow-Origin" $http_origin;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains;
preload" always;
# log files
access_log /var/log/virtualmin/example.com_access_log;
error_log /var/log/virtualmin/example.com_error_log;
include /home/user/public_html/nginx.conf;
location = ^/favicon.ico {
log_not_found off;
access_log off;
location = ^/robots.txt {
allow all;
log_not_found off;
access_log off;
# Deny access to uploads that aren’t images, videos, music, etc.
location ~* ^/wp-content/uploads/.*.(html|htm|shtml|php|js|swf)$ {
access_log off;
log_not_found off;
deny all;
# Deny public access to wp-config.php
location ~* wp-config.php {
deny all;
location / {
location ~ \.php$ {
location ~ \.php$ {
**#----- redirect to mobile check (starts) -----#**
** set $mobile_rewrite do_not_perform;**
** if ($http_user_agent ~* “(android|bb\d+|meego).+mobile|avantgo|bada/|blackberry|blazer|compal|elaine|fennec|hiptop|iemobile|ip(hone|od)|iris|kindle|lge |maemo|midp|mmp|mobile.+firefox|netfront|opera m(ob|in)i|palm( os)?|phone|p(ixi|re)/|plucker|pocket|psp|series(4|6)0|symbian|treo|up.(browser|link)|vodafone|wap|windows ce|xda|xiino”) {**
** set $mobile_rewrite perform;**
** if ($http_user_agent ~* “^(1207|6310|6590|3gso|4thp|50[1-6]i|770s|802s|a wa|abac|ac(er|oo|s-)|ai(ko|rn)|al(av|ca|co)|amoi|an(ex|ny|yw)|aptu|ar(ch|go)|as(te|us)|attw|au(di|-m|r |s )|avan|be(ck|ll|nq)|bi(lb|rd)|bl(ac|az)|br(e|v)w|bumb|bw-(n|u)|c55/|capi|ccwa|cdm-|cell|chtm|cldc|cmd-|co(mp|nd)|craw|da(it|ll|ng)|dbte|dc-s|devi|dica|dmob|do(c|p)o|ds(12|-d)|el(49|ai)|em(l2|ul)|er(ic|k0)|esl8|ez([4-7]0|os|wa|ze)|fetc|fly(-|)|g1 u|g560|gene|gf-5|g-mo|go(.w|od)|gr(ad|un)|haie|hcit|hd-(m|p|t)|hei-|hi(pt|ta)|hp( i|ip)|hs-c|ht(c(-| ||a|g|p|s|t)|tp)|hu(aw|tc)|i-(20|go|ma)|i230|iac( |-|/)|ibro|idea|ig01|ikom|im1k|inno|ipaq|iris|ja(t|v)a|jbro|jemu|jigs|kddi|keji|kgt( |/)|klon|kpt |kwc-|kyo(c|k)|le(no|xi)|lg( g|/(k|l|u)|50|54|-[a-w])|libw|lynx|m1-w|m3ga|m50/|ma(te|ui|xo)|mc(01|21|ca)|m-cr|me(rc|ri)|mi(o8|oa|ts)|mmef|mo(01|02|bi|de|do|t(-| |o|v)|zz)|mt(50|p1|v )|mwbp|mywa|n10[0-2]|n20[2-3]|n30(0|2)|n50(0|2|5)|n7(0(0|1)|10)|ne((c|m)-|on|tf|wf|wg|wt)|nok(6|i)|nzph|o2im|op(ti|wv)|oran|owg1|p800|pan(a|d|t)|pdxg|pg(13|-([1-8]|c))|phil|pire|pl(ay|uc)|pn-2|po(ck|rt|se)|prox|psio|pt-g|qa-a|qc(07|12|21|32|60|-[2-7]|i-)|qtek|r380|r600|raks|rim9|ro(ve|zo)|s55/|sa(ge|ma|mm|ms|ny|va)|sc(01|h-|oo|p-)|sdk/|se(c(-|0|1)|47|mc|nd|ri)|sgh-|shar|sie(-|m)|sk-0|sl(45|id)|sm(al|ar|b3|it|t5)|so(ft|ny)|sp(01|h-|v-|v )|sy(01|mb)|t2(18|50)|t6(00|10|18)|ta(gt|lk)|tcl-|tdg-|tel(i|m)|tim-|t-mo|to(pl|sh)|ts(70|m-|m3|m5)|tx-9|up(.b|g1|si)|utst|v400|v750|veri|vi(rg|te)|vk(40|5[0-3]|-v)|vm40|voda|vulc|vx(52|53|60|61|70|80|81|83|85|98)|w3c(-| )|webc|whit|wi(g |nc|nw)|wmlb|wonu|x700|yas-|your|zeto|zte-)”) {**
** if ($mobile_rewrite = perform) {**
** rewrite ^ https://mobile.example.com$request_uri? redirect;**
** break;**
** #----- redirect to mobile check (ends) -----#**
Please, after all these setup, when I visit mobile.example.com on mobile phone, it shows nothing on the page and only says mobile.example.com has too many redirects.
Please, what am I doing wrong? I will forever be grateful and indebted to any person who will help me out with a solution. Many, many thanks in advance.
