Hi all,
<p>
New versions of Webmin and Usermin are available for all platforms.
<p>
Webmin changes since 1.320:
<p>
[list]
[*]If the underlying OS is upgraded after Webmin is installed, a message
is displayed on the main page prompting you to fix it.[/*]
[*]Added a feature in the BIND module for updating an IP address in multiple zones at once.[/*]
[*]The File Manager now automatic detects HTML files and launches the correct editor.[/*]
[*]Improved the LDAP module's support for large databases.[/*]
[*]When there are too many tables or databases to display in the MySQL and PostgreSQL modules, a menu for selecting a specific table is shown instead.[/*]
[*]Added functions to ui-lib.pl for tabs and hidden table sections.[/*]
[*]Added support for comments to the Shorewall module, and improved logging .[/*]
[*]The Webmin Actions Log module can now rollback selected files changed by an action, rather than all of them.[/*]
[*]View the[a href="http://www.webmin.com/changes-1.330.html">detailed change log</a>.[/*]
[/list]
<p>
Usermin changes since 1.240:
<p>
[list]
[*]Changed the default theme to the new Blue framed theme.[/*]
[*]Added tabs to the Compose Email page, to allow bigger To:/Cc: fields.[/*]
[*]Fields for client-side attachments are now dynamically generated.[/*]
[*]Added the Filter Mail module, which provides a simpler interface to Procmail and is better integrated with the Read Mail module's folder system.[/*]
[*]Added a popup window for tracking file uploads in various modules.[/*]
[*]View the[a href="http://www.webmin.com/uchanges-1.260.html">detailed change log</a>.[/*]
[/list]
<p>
To upgrade on Red Hat based systems:
<p>
yum update webmin usermin
<p>
On SUSE systems:
<p>
yast -i webmin usermin
<p>
On Mandriva systems:
<p>
urpmi webmin usermin
<p>
And on Debian/Ubuntu systems:
<p>
apt-get update
apt-get install webmin usermin
<p>
Please let us know if you run into any problems by filing an issue in the bug tracker.
