I did the upgrade today to Webmin version 1.800 on CentOS 6.7 i686 with PHP7installed
Webmin works, I can go to servers etc. But the info screen ain’t working. Instead I get this message:
HTTP/1.0 500 Perl execution failed Server: MiniServ/1.800 Date: Thu, 26 May 2016 10:42:15 GMT Content-type: text/html; Charset=iso-8859-1 Connection: close
Error - Perl execution failed
Can’t locate auto/Net/SSLeay/set_tlsext_.al in @INC (@INC contains: authentic-theme/lib /usr/libexec/webmin /usr/local/lib/perl5 /usr/local/share/perl5 /usr/lib/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib/perl5 /usr/share/perl5 . …) at /usr/libexec/webmin/web-lib-funcs.pl line 7350
How I fix this one?
PS: I hear not so positive comments about ‘webtatic’ repo, should it be disabled?
Added: Later today I will:
Disable webtatic and do an update.
yum update --disablerepo=webtatic
The server has some email that need to work during workhours, just in case the update brings other issues as I didn’t restart postfix after the PHP7 upgrade.
