I have a domain, let’s call it domain.com. In the DNS zone domain.com, I created a subdomain webmail.domain.com and I put on it the address xxx.xxx.xxx.xxx. And I want it to use standard https port, 443.
I would like to bind usermin to this IP and port, but I cannot… it always says in miniserv error log :
Address already in use at /usr/local/usermin-1.290/miniserv.pl line 407.
How comes? And how can I bind it to this url in https mode?
I decided to switch from squirrelmail to usermin, but squirrelmail is a simple webmail and it is easy to configure it this way… I just have to put squirrelmail folder where I want it to, create an apache vhost config with this IP and http port, with the good root document, and that’s all… and with usermin?
By creating a virtual server there, you’ve taken the port for Apache. Usermin doesn’t run under Apache, and the two can’t share an IP:port combination.
So, disable SSL for that domain, and then restart Usermin.
Thanks for your help. I tried something… I stopped apache, I changed usermin ports, and start usermin, and it worked… fine…
Then I started apache again and I had the error :
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:443
no listening sockets available, shutting down
So it seems my address xxx.xxx.xxx.xxx:443 is in conflict with the address 0.0.0.0:443. How is it possible and how can I fix it?
You say removing apache ssl, but just for IP xxx.xxx.xxx.xxx, right? Where do I do that?
Ok I found… thanks to webmin was easy to disable SSL for my webserver
I can promise nothing but in a few months when my boss will see the power of the new website, I’ll ask him to make a donation… or to buy the pro version ^^ btw what’s the differences in the pro?
'night, time for me to sleep, it is past midnight here in france…
