Need help making 'Shared IP's
Having to change all the IPs on the server… But I can’t make the 2nd one shared.
I Do…
Webmin >> Network Configuration >> Network Interface >> Add IP
Then
Virtualmin >> Addresses and Networking >>Shared IP Addresses >> Add IP
Then change a server to that IP …
Virtualmin >> Edit Virtual Server >> Configurable settings >-> Create now with IP >-> check "Already active"
That works… site up …
Then try change the 2nd site to the same IP and it tells me is it a "Private IP"
What am I missing…
Don
Hey Don,
I’m not certain what the problem is there – however, if you don’t get an answer from someone shortly, I might file an issue in the Bug Tracker, it’s possible what you’re seeing is a bug.
Thanks,
