Need help in smtp not work
Please only show us relevant log entries. Please never send the whole danged thing. We can’t make any sense out of that, and it’s asking for us to spend a bunch of time guessing at which lines are relevant.
To get relevant log entries:
Start tailing the log (use tail -f <log path> or journalctl -fu postfix) and then perform the action that is failing. The log entries that appear immediately after you do that are probably the relevant ones, and the only ones we want to see. It would only be three or four lines, tops.
If you don’t see any, it’s because you have a network problem. Port’s closed, perhaps. Could also be a DNS problem.
maybe this would help ?
Sorry about that
Can you tell me what is the name of the required file and where can I find it?
‫في الثلاثاء، 27 أغسطس 2024 في 11:12 ص تمت كتابة ما يلي بواسطة ‪jimr via Virtualmin Community‬‏ <‪noreply@forum.virtualmin.com‬‏>:‬
Normally /var/log/mail.log but perhaps use the journalctl command as mentioned before as this is independent of needing the log file
2024-08-27T11:03:14.206659+00:00 hy76 postfix/smtpd[242512]: disconnect from unknown[120.138.13.66] ehlo=1 auth=0/1 commands=1/2
2024-08-27T11:03:15.022480+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:03:15.354908+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:15.355205+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:16.060795+00:00 hy76 postfix/smtpd[242553]: warning: hostname abts-mum-static-139.98.170.122.airtelbroadband.in does not resolve to address 122.170.98.139: Name or service not known
2024-08-27T11:03:16.061212+00:00 hy76 postfix/smtpd[242553]: connect from unknown[122.170.98.139]
2024-08-27T11:03:22.078221+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:03:22.703669+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:22.703974+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:22.837637+00:00 hy76 postfix/smtpd[242553]: warning: unknown[122.170.98.139]: SASL LOGIN authentication failed: authentication failure, sasl_username=support@hy76.com
2024-08-27T11:03:23.663488+00:00 hy76 postfix/smtpd[242553]: lost connection after AUTH from unknown[122.170.98.139]
2024-08-27T11:03:23.663962+00:00 hy76 postfix/smtpd[242553]: disconnect from unknown[122.170.98.139] ehlo=1 auth=0/1 commands=1/2
2024-08-27T11:03:28.345189+00:00 hy76 postfix/smtpd[241604]: connect from unknown[194.169.175.33]
2024-08-27T11:03:28.926219+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:03:29.987239+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[194.169.175.33]
2024-08-27T11:03:29.987524+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[194.169.175.33] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:30.368931+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:30.369173+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:31.369988+00:00 hy76 postfix/anvil[1840]: statistics: max connection rate 10/60s for (submission:83.222.190.50) at Aug 27 10:53:35
2024-08-27T11:03:31.370276+00:00 hy76 postfix/anvil[1840]: statistics: max connection count 1 for (submission:194.169.175.33) at Aug 27 10:53:34
2024-08-27T11:03:31.370501+00:00 hy76 postfix/anvil[1840]: statistics: max cache size 8 at Aug 27 11:03:17
2024-08-27T11:03:35.825329+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:03:36.387549+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:36.387912+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:42.662646+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:03:43.160406+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:43.160767+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:47.399221+00:00 hy76 postfix/smtpd[241604]: connect from unknown[194.169.175.33]
2024-08-27T11:03:47.836896+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:03:48.187707+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:48.188159+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:50.968014+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[194.169.175.33]
2024-08-27T11:03:50.968316+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[194.169.175.33] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:53.461230+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:03:54.006680+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:03:54.007008+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:03:59.728887+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:04:00.174806+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:00.175132+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:06.324883+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:06.828726+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:06.829125+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:10.253950+00:00 hy76 postfix/smtpd[241604]: connect from unknown[194.169.175.33]
2024-08-27T11:04:10.550894+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[194.169.175.33]
2024-08-27T11:04:10.551139+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[194.169.175.33] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:11.873430+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:12.343136+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:12.343421+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:18.372636+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:04:18.713349+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:18.713913+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:25.136982+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:25.692734+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:25.693138+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:29.870091+00:00 hy76 postfix/smtpd[241604]: connect from unknown[194.169.175.33]
2024-08-27T11:04:31.113860+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[194.169.175.33]
2024-08-27T11:04:31.114413+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[194.169.175.33] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:31.935891+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:32.689245+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:32.689735+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:38.988287+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:04:39.923733+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:39.924166+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:45.932423+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:46.282450+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:46.282817+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:49.127482+00:00 hy76 postfix/smtpd[241604]: connect from unknown[194.169.175.33]
2024-08-27T11:04:50.103580+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[194.169.175.33]
2024-08-27T11:04:50.103981+00:00 hy76 postfix/smtpd[241604]: disconnect from unknown[194.169.175.33] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:52.787808+00:00 hy76 postfix/smtpd[239940]: connect from unknown[83.222.190.50]
2024-08-27T11:04:53.181874+00:00 hy76 postfix/smtpd[239940]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T11:04:53.182187+00:00 hy76 postfix/smtpd[239940]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T11:04:59.851519+00:00 hy76 postfix/smtpd[241604]: connect from unknown[83.222.190.50]
2024-08-27T11:05:00.263533+00:00 hy76 postfix/smtpd[241604]: lost connection after AUTH from unknown[83.222.190.50]
Again alot of logs with repeating errors, its not needed.
These are the last lines
2024-08-27T12:25:48.120707+00:00 hy76 postfix/smtpd[268606]: connect from unknown[218.149.200.51]
2024-08-27T12:25:49.515724+00:00 hy76 postfix/smtpd[267834]: connect from unknown[83.222.190.50]
2024-08-27T12:25:50.174285+00:00 hy76 postfix/smtpd[267834]: lost connection after AUTH from unknown[83.222.190.50]
2024-08-27T12:25:50.174492+00:00 hy76 postfix/smtpd[267834]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T12:25:58.430706+00:00 hy76 postfix/smtpd[268606]: warning: unknown[218.149.200.51]: SASL LOGIN authentication failed: authentication failure, sasl_username=inf@hy76.com
2024-08-27T12:25:59.508453+00:00 hy76 postfix/smtpd[268606]: lost connection after AUTH from unknown[218.149.200.51]
2024-08-27T12:25:59.508995+00:00 hy76 postfix/smtpd[268606]: disconnect from unknown[218.149.200.51] ehlo=1 auth=0/1 commands=1/2
2024-08-27T12:26:01.096641+00:00 hy76 postfix/smtpd[268606]: connect from unknown[14.6.16.137]
2024-08-27T12:26:11.074819+00:00 hy76 postfix/smtpd[268606]: warning: unknown[14.6.16.137]: SASL LOGIN authentication failed: authentication failure, sasl_username=inf@hy76.com
2024-08-27T12:26:12.215074+00:00 hy76 postfix/smtpd[268606]: lost connection after AUTH from unknown[14.6.16.137]
2024-08-27T12:26:12.215357+00:00 hy76 postfix/smtpd[268606]: disconnect from unknown[14.6.16.137] ehlo=1 auth=0/1 commands=1/2
2024-08-27T12:27:33.292466+00:00 hy76 dovecot: imap-login: Disconnected: Connection closed (auth failed, 1 attempts in 4 secs): user=<info@hy76.com>, method=PLAIN, rip=191.252.92.50, lip=165.16.6.110, session=<oyRvXakgUKW//Fwy>
2024-08-27T12:27:53.243725+00:00 hy76 postfix/smtpd[265731]: timeout after AUTH from unknown[83.222.190.50]
2024-08-27T12:27:53.244154+00:00 hy76 postfix/smtpd[265731]: disconnect from unknown[83.222.190.50] ehlo=1 auth=0/1 rset=1 commands=2/3
2024-08-27T12:28:55.491108+00:00 hy76 postfix/smtpd[266941]: timeout after CONNECT from unknown[83.222.190.50]
2024-08-27T12:28:55.492506+00:00 hy76 postfix/smtpd[266941]: disconnect from unknown[83.222.190.50] commands=0/0
‫في الثلاثاء، 27 أغسطس 2024 في 2:55 م تمت كتابة ما يلي بواسطة ‪stefan1959 via Virtualmin Community‬‏ <‪noreply@forum.virtualmin.com‬‏>:‬
Currently, messages have been sent even to Google, but there is an issue with receiving them, as it shows an “incomplete authentication” message.
outlook is not work test 995 ssl lts 110 smtp test 465 587 ss and ls whats can do
What should I do?
No idea the screen shot is not in English but perhaps you don’t have the ports open or your email client is looking elsewhere maybe another port. You need to supply more information about your setup
“Unable to verify your identity: () SMTP error.”
Have you tried to use usermin to read your email ? If you can see your email there it would appear you have a wrongly configured email client… log into usermin using
https://yourdomain.tld:20000
Yes, it is working for sending emails, but I am not receiving any messages either.
Roundcube gets this message if I send and do not receive any messages. Also, the Outlook is not working
so usermin is not receiving messages but it can send or are you referring to roundcube ?
*From the site https://yourdomain.tld:20000, I can successfully send emails
** Roundcube and Outlook, I cannot them.
Nothing really wrong with the mail server as usermin sends email.
you need to fix everything else, that said your domain, if it’s to be believed, has no mail dns records… good luck fixing this problem
I will check what you mentioned
hello all my answer is
sudo fail2ban-client set dovecot unbanip ip
just that and all is work
thanks all for help me all this time
You can see and unban in the GUI
cool i get thanks
