Need help, FTP Failed to connect to FTP server : PASS *********** failed : Login authentication failed
hello sir, i need help,
i’m trying to scheduled backup using ftp from source server to destination server,
but always “failed : Login authentication failed”.
i trying test login using filezilla from windows and ftp in console from source server always work but only in schedule backup always failed.
destination ftp server using pureftpd port 21,
i have checking log message on /var/log/messages. only from scheduled backup failed, ftp console or filezilla success.
whats should i do again
here log message in destination server
Filezilla windows10:
Dec 3 17:45:19 vps pure-ftpd: (?@ccc.ccc.ccc.ccc) [INFO] New connection from ccc.ccc.ccc.ccc
Dec 3 17:45:19 vps pure-ftpd: (?@ccc.ccc.ccc.ccc) [INFO] SNI: [destination.com]
Dec 3 17:45:19 vps pure-ftpd: (?@ccc.ccc.ccc.ccc) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES256-GCM-SHA384, 256 secret bits cipher
Dec 3 17:45:19 vps pure-ftpd: (?@ccc.ccc.ccc.ccc) [INFO] dest@destination.com is now logged in
Dec 3 17:45:20 vps pure-ftpd: (dest@destination.com@ccc.ccc.ccc.ccc) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES256-GCM-SHA384, 256 secret bits cipher
here virtualminbackup from source server :
Dec 3 17:45:42 vps pure-ftpd: (?@xxx.xxx.xxx.xxx) [INFO] New connection from xxx.xxx.xxx.xxx
Dec 3 17:45:47 vps pure-ftpd: (?@xxx.xxx.xxx.xxx) [WARNING] Authentication failed for user [dest@destination.com]
Dec 3 17:45:47 vps pure-ftpd: (?@xxx.xxx.xxx.xxx) [INFO] Logout.
testing from ssh console ftp from source server :
Dec 3 17:48:41 vps pure-ftpd: (?@xxx.xxx.xxx.xxx) [INFO] New connection from xxx.xxx.xxx.xxx
Dec 3 17:48:54 vps pure-ftpd: (?@xxx.xxx.xxx.xxx) [INFO] dest@destination.com is now logged in
Dec 3 17:49:01 vps systemd: Started Session 281519 of user root.
Dec 3 17:49:01 vps systemd: Started Session 281520 of user root.
Dec 3 17:49:16 vps clamd: SelfCheck: Database status OK.
Dec 3 17:49:24 vps pure-ftpd: (dest@destination.com@xxx.xxx.xxx.xxx) [INFO] Logout.
-sh-4.2$ ftp destination.com
Connected to destination.com (yyy.yyy.yyy.yyy).
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 2 of 50 allowed.
220-Local time is now 06:48. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
Name (destination.com:slj): dest@destination.com
331 User dest@destination.com OK. Password required
Password:
230-This server supports FXP transfers
230 OK. Current restricted directory is /
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> ls
227 Entering Passive Mode (yyy,yyy,yyy,yyy,118,16)
150 Accepted data connection
Setting in scheduled backup:
FTP Server 103.133.56.237
File on server /lxxx-source-sql.tar.gz
Login as user dest@destination.com
with password *****
**Operating system:All both CENTOS 7
OS version:
