I have a site that doesn’t come up sometimes… instead, the default site on the SECONDARY nameserver appears - even though the site is hosted on the primary nameserver’s box.
I can’t figure it out, and I need to right away before I get fired.
IntoDNS is reporting:
Looks like the A records (the GLUE) got from the parent zone check are different than the ones got from your nameservers. You have to make sure your parent server has the same NS records for your zone as you do.I detected some problems as follows:
For ns1.domain.com the parent reported: [‘xx.xxx.xx.186’] and your nameservers reported: [‘xx.xx.xx.186’, ‘yy.yyy.yyy.yy’]
for the registered nameservers at the parent (registrar) you need to make A records on your box. Well you did but apparently there are differences.
at the registrar your register nameservers. ns1.domain.com with IP.
This IP will be your glue on your box, this is done as A record. Those two IP’s obviously must be the same as they are the same.
Also, at least two of my domains are returning the ip address of the secondary name server itself, instead of the ip address of the primary, which is where the website is…
eg., I just noticed that intodns says
The MX records that are not the same at all your nameservers: mail.domain.com with ip(s): xx.xxx.xx.186 reported only by: xx.xxx.xx.186 mail.domain.com with ip(s): yy.yyy.yyy.yy reported only by: yy.yyy.yyy.yy
It is better to have the same MX records at all your nameservers!
In their zone… what on earth could possibly be causing this? I don’t have access to the registrar where the domains were created but I already told me boss to triple check this while I was at work and he swears the records are the same.
the slave nameserver has A records pointing to wherever the domain is hosted. Often the primary server.
on the primary there is an A record for the slave nameserver
at the registrar you’d just have the nameservers so your nameserver is authorative
But, for instance, if you go to http://www.webdnstools.com and run the “Check domain configuration” tool, if it uses ns2 as the server to conduct the test it reports
Inconsistencies were found between the glue records on the parent servers and the glue records on this nameserver.
And if this is NOT the problem, then what might it be? And there definitely is a problem because when you go to perryheatingandcooling.com you often get the wrong site. In fact, it’s so bad, I had the WRONG site just try to bounce to the correct site for now, since perryheatingandcooling.com is more important.
And, also, it doesn’t happen EVERY time… just some times.
Ok, if I turned off ns2’s name server, it actually worked and got the web sites to come up… so, thinking that might hopefully mean the bug was on ns2, I completely reinstalled the OS and Virtualmin , never entered the IP for the ns1 server in any way, and when I started bind the error came RIGHT back…
So the error must be on ns1.
But… WHERE can I go to chance the ns1 IP so that it only has the one record?
I’ve checked just about everywhere I can think of…
Webmin-networking-network configuration
In /etc/hosts it lists only 127.0.0.1 and I left that alone…
module config lists the right addresses as far as I can tell…
Where would I change the IP address? This has been going on for days now… apparently I entered the wrong IP address at one time and now I cant figure out where or how to remove it… so, please, help…
you would have to look in the zone files and look for a double entry on the ns1 A record.
the zonefile is wildwestcloud.com and can be seen in the bind dns module.
