Hi all, I m newbie to virtualmin, I faced a difficulty and I hope anyone can help me, thanks a lot!
Here is my situation:
I have a server which is Centos 5 and installed virtualmin.
I have applied a domain “abc.com” from a domain provider, however, this domain provider has no DNS record management, so I can only add nameserver to this domain to point the domain to my server.
But I m still confused, I hope anyone can guide me step by step.
First, for my server , what should I set? How do I setup a nameserver so I can provide this nameserver to my domain provider? Like ns1.myanotherdomain.com?
Q1) Should I use another domain which has DNS management, to create a DNS record called ns1.myanotherdomain.com? If yes, is it pointing to my server?
Q2) How do I setup a nameserver for my server?
Please try to explain me as detail as you can, thanks
Thanks for your help.
From your guide, when I come to this line:
After registering your nameservers at your domain name registrar – you’ll want to log into Virtualmin, select your “example.com” domain, click Server Configuration -> DNS Records, and create a new “A - IPv4 Address” record for ns1.example.com and ns2.example.com.
I cannot find where to create the IPv4 record for my ns1.mydomain?
