Hello.
I just installed new VM with fresh centos 77-1908
I installed virtualmin and I ahve logged in and I did the Re-Check Configuration System was ready but I had to add a MYSQL password as always
I continue the link and there is a form to fill the password twice for confirmation and there is a message saying that there is no password.
I wrote the password twice and cliked save button. I received a error message.
Failed to change administration password : DBI connect failed : Access denied for user ‘root’@‘localhost’ (using password: NO)
I restarted the MySQL server form the dashboard and suddenly it has disappeared.
I seen a message before that mysqld is not installed but I don’t remeber the exact message.
I used the commands and downloaded the same files, like. install.sh
What’s wrong?
Thank you
Regards.
