mysql is not runing on debian system! please help
hello
suddenly mysql stop working.
i am using debian squezze distro and virtualmin latest version.
virtualmin doesn’t recognise it and i can’t see any log for mysql
MySQL has been enabled, but cannot be used by Virtualmin. Use the MySQL Database module to fix the problem.
when i click to enable the mysql
i receive the following error
MySQL is not running on your system - database list could not be retrieved.
i try to reinstall mysql from shell but no luck…
please instruct… also i can’t see any error log files… all are empty…
What is the output of these commands:
dpkg -l 'mysql*' ps auxw | grep mysql
hello the output is the following
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Description
ii mysql-client 5.1.73-1 MySQL database client (metapackage depending
un mysql-client-4 (no description available)
un mysql-client-5 (no description available)
ii mysql-client-5 5.1.73-1 MySQL database client binaries
ii mysql-common 5.1.73-1 MySQL database common files, e.g. /etc/mysql
un mysql-common-4 (no description available)
ii mysql-server 5.1.73-1 MySQL database server (metapackage depending
un mysql-server-4 (no description available)
un mysql-server-5 (no description available)
ii mysql-server-5 5.1.73-1 MySQL database server binaries and system da
un mysql-server-c (no description available)
ii mysql-server-c 5.1.73-1 MySQL database server binaries
root 27962 0.0 0.0 8076 844 pts/11 S+ 18:13 0:00 grep mysql
ii mysql-client 5.1.73-1 MySQL database client (metapackage depending on the latest version)
un mysql-client-4.1 (no description available)
un mysql-client-5.0 (no description available)
ii mysql-client-5.1 5.1.73-1 MySQL database client binaries
ii mysql-common 5.1.73-1 MySQL database common files, e.g. /etc/mysql/my.cnf
un mysql-common-4.1 (no description available)
ii mysql-server 5.1.73-1 MySQL database server (metapackage depending on the latest version)
un mysql-server-4.1 (no description available)
un mysql-server-5.0 (no description available)
ii mysql-server-5.1 5.1.73-1 MySQL database server binaries and system database setup
un mysql-server-core (no description available)
un mysql-server-core-5.0 (no description available)
ii mysql-server-core-5.1 5.1.73-1 MySQL database server binaries
What output do you receive if you try to start MySQL using this command:
/etc/init.d/mysql restart
i receive nothing
. and the mysql not restarts
i receive nothing
sorry for the multiple reply… something went wrong…
any help on that?
