Operating system: CentOS
OS version: 8 64 bit
Clean OS installs on two VPSs, intending to use as DNS servers so installed Webmin. End of automated procedure in each instance was the message that it is now OK to go to mydomain.com:10000 and log in. FF tells me it is unable to connect. Can’t even get a login page to show.
I have two other VPSs with Virtualmin. No such problem, although one of those is not authenticating (separate ticket under the Virtualmin section).
Each VPS has an A record pointing at its IP address. I can shell into all of them.
Ideas to pursue appreciated. A solution would be a real blessing.
TIA,
Mike
