Hi again,
now I’m able to retrieve and send emails with my domains I’m facing an issue with SSL certificates.
I’ve created 2 domains with SSL from Let’s encrypt for each.
I’ve copied both to Dovecot using the copy button .
If I look into the /etc/postfix/master.cf file both certificates are references on the good IP (for each domain attached to it owns IP address).
But when I try to access to the email account from an email client only the last copied certificate is proposed. So the other domain get an SSL warning due to a certificate not related to its domain.
How can I fix this ? I want to be able to have an SSL certificate for each site (this part is working well) but also the corresponding SSL certificate used for emails.
Thansk in advance.
