Multiple SSL certificates for differtent domains suddenly not working anymore?
I have 2 VPS setup and both of them have a couple website on it.
On both VPS systems I have 2 domains using SSL, with a different certificate. I beleive this used to work fine on both systems, however at the moment 1 system is showing the same certificate for every domain, which results in invalid SSL for the domains that the certificate is not issued for.
On the other systems, I can access both websites via https:// and both websites will show their own certificate in the browser once I inspect this.
Do you have any help or suggestions on this. The virtualmin and webmin versions for both are exactly the same, so what’s causing one server to assign SSL certificates to the domains correctly and the other not?
Hope you can help me out asap, I am clueless of where to look at the moment.
Thanks a lot as always!
PS: I do see that the virtualmin version for the server that does NOT work anymore is 5.04, for the server where it works fine the version is 5.0
Can this be related to the 5.04 version?
