hi,
i was following the multiple php install for centos according to"
https://www.virtualmin.com/documentation/web/multiplephp
but it couldn’t find the php5.6 rpm:
rpm -Uvh https://www.softwarecollections.org/en/scls/rhscl/rh-php56/epel-7-x86_64/download/rhscl-rh-php56-epel-7-x86_64.noarch.rpm
Retrieving https://www.softwarecollections.org/en/scls/rhscl/rh-php56/epel-7-x86_64/download/rhscl-rh-php56-epel-7-x86_64.noarch.rpm
curl: (22) The requested URL returned error: 404 Not Found
error: skipping https://www.softwarecollections.org/en/scls/rhscl/rh-php56/epel-7-x86_64/download/rhscl-rh-php56-epel-7-x86_64.noarch.rpm - transfer failed
i navigated the softwarecollections directories and found a php5.6 rpm:
rpm -Uvh https://www.softwarecollections.org/repos/rhscl/rh-php56/epel-7-x86_64/noarch/rhscl-rh-php56-epel-7-x86_64.noarch.rpm
Retrieving https://www.softwarecollections.org/repos/rhscl/rh-php56/epel-7-x86_64/noarch/rhscl-rh-php56-epel-7-x86_64.noarch.rpm
Preparing… ################################# [100%]
Updating / installing…
1:rhscl-rh-php56-epel-7-x86_64-1-2 ################################# [100%]
then followed the rest of the virtualmin documentation:
[root@server ~]# yum install rh-php56 rh-php56-php-mysqlnd
Loaded plugins: fastestmirror
rhscl-rh-php56-epel-7-x86_64 | 3.0 kB 00:00
rhscl-rh-php56-epel-7-x86_64/primary_db | 29 kB 00:00
Loading mirror speeds from cached hostfile
- base: repo1.dal.innoscale.net
- epel: fedora-epel.mirror.lstn.net
- extras: repo1.dal.innoscale.net
- updates: repo1.dal.innoscale.net
Package rh-php56-php-mysqlnd-5.6.5-9.el7.x86_64 already installed and latest version
Resolving Dependencies
–> Running transaction check
—> Package rh-php56.x86_64 0:2.0-6.el7 will be updated
—> Package rh-php56.x86_64 0:2.0-6.el7.centos will be an update
–> Processing Dependency: rh-php56-runtime(x86-64) = 2.0-6.el7.centos for package: rh-php56-2.0-6.el7.centos.x86_64
—> Package rh-php56-runtime.x86_64 0:2.0-6.el7 will be updated
—> Package rh-php56-runtime.x86_64 0:2.0-6.el7.centos will be an update
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
rh-php56 x86_64 2.0-6.el7.centos rhscl-rh-php56-epel-7-x86_64 3.9 k
Updating for dependencies:
rh-php56-runtime x86_64 2.0-6.el7.centos rhscl-rh-php56-epel-7-x86_64 1.1 M
Transaction Summary
Upgrade 1 Package (+1 Dependent package)
Total download size: 1.2 M
Is this ok [y/d/N]: y
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
(1/2): rh-php56-2.0-6.el7.centos.x86_64.rpm | 3.9 kB 00:00
(2/2): rh-php56-runtime-2.0-6.el7.centos.x86_64.rpm | 1.1 MB 00:00
Total 1.4 MB/s | 1.2 MB 00:00
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
Updating : rh-php56-runtime-2.0-6.el7.centos.x86_64 1/4
Updating : rh-php56-2.0-6.el7.centos.x86_64 2/4
Cleanup : rh-php56-2.0-6.el7.x86_64 3/4
Cleanup : rh-php56-runtime-2.0-6.el7.x86_64 4/4
Verifying : rh-php56-2.0-6.el7.centos.x86_64 1/4
Verifying : rh-php56-runtime-2.0-6.el7.centos.x86_64 2/4
Verifying : rh-php56-2.0-6.el7.x86_64 3/4
Verifying : rh-php56-runtime-2.0-6.el7.x86_64 4/4
Updated:
Dependency Updated:
Complete!
i hope that i didn’t mess up any repos. but wanted to check that what i did was okay.
like, why doesn’t everyone else get a 404 error with the documented repo?
thanks,
