I am trying to edit an account but keep getting this error: ‘Module spam does not exist’
I have checked in the shell to see if spamassassin is installed and it is. Any idea what I screwed up?
Thanks again,
-Jason
Thanks again,
-Jason
Hmm… how did you install Virtualmin, was it with the install.sh script?
If you go into System Settings -> Features and Plugins, do you see the Spam feature available in there? If so, is that enabled?
Yes I did, but I think I may have removed it. I dont need it since I do offiste mail filtering for my domains.
When I go to features it is selected but when I try to unselect it get this error:
“Failed to save enabled features : The feature Spam filtering cannot be disabled, as it is used by the following virtual servers : garryowen.trackpads.com news.trackpads.com trackpads.com”
However, if I try to edit any of those servers I dont get any options to disable it, just an error under configurable options that says:
“Module spam does not exist”
And no other options.
Thanks again,
-Jason
