VM successfully installed 8 of the 9 updates. However, one failed (twice). Is this a temporary condition or is there another problem?
[code:1]
Installing package(s) with command yum -y install wbm-virtual-server …
Setting up Install Process
Parsing package install arguments
Resolving Dependencies
–> Running transaction check
—> Package wbm-virtual-server.noarch 2:3.64-1 set to be updated
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Updating:
wbm-virtual-server noarch 2:3.64-1 virtualmin-universal 3.1 M
Transaction Summary
Install 0 Package(s)
Update 1 Package(s)
Remove 0 Package(s)
Total download size: 3.1 M
Downloading Packages:
http://software.virtualmin.com/universal/wbm-virtual-server-3.64-1.noarch.rpm: [Errno 4] Socket Error: timed out
Trying other mirror.
Error Downloading Packages:
2:wbm-virtual-server-3.64-1.noarch: failure: wbm-virtual-server-3.64-1.noarch.rpm from virtualmin-universal: [Errno 256] No more mirrors to try.
… install failed!
[/code:1]
