SYSTEM INFORMATION | |
OS type and version | Debian 11 |
Virtualmin version | 7.7 |
Hi Community,
I finally have a new Virtualmin Server. This time with NGINX on it.
Since it’s my first time using NGINX, I want to ask you guys if you may can help out in modifying my NGINX config, maybe in a better way. Not sure, but until now everything is working.
What I did so far, was to put the rule inside this config, which Wordress generates in the .htaccess file on a Apache Server.
This is my config so far:
server {
server_name xxxtest.dedyn.io www.xxxtest.dedyn.io mail.xxxtest.dedyn.io;
listen 207.123.456.175;
listen [2605:1234:5678:1341::100] default_server;
root /home/xxxtest/public_html;
index index.php index.htm index.html;
access_log /var/log/virtualmin/xxxtest.dedyn.io_access_log;
error_log /var/log/virtualmin/xxxtest.dedyn.io_error_log;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_FILENAME "/home/xxxtest/public_html$fastcgi_script_name";
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT /home/xxxtest/public_html;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param PATH_INFO $fastcgi_path_info;
fastcgi_param HTTPS $https;
location ^~ /.well-known/ {
try_files $uri /;
location / {
try_files $uri $uri/ /index.php?$args;
location ~ "\.php(/|$)" {
try_files $uri $fastcgi_script_name =404;
default_type application/x-httpd-php;
fastcgi_pass unix:/var/php-fpm/16821413252991.sock;
fastcgi_split_path_info "^(.+\.php)(/.+)$";
location /cgi-bin/ {
gzip off;
root /home/xxxtest/cgi-bin;
fastcgi_pass unix:/var/fcgiwrap/16821413252991.sock/socket;
fastcgi_param SCRIPT_FILENAME "/home/xxxtest$fastcgi_script_name";
listen 207.123.456.175:443 ssl;
listen [2605:1234:5678:1341::100]:443 ssl default_server;
ssl_certificate /etc/ssl/virtualmin/16821413252991/ssl.combined;
ssl_certificate_key /etc/ssl/virtualmin/16821413252991/ssl.key;
I’m not sure at this point if there’s a way to make this configuration even better.
Thanks a lot upfront.
