Misunderstanding "copy to xxx" SSL certs
Strange.
It’s been a while since I performed a dist-upgrade on a production server, but can’t remember running into these issues, everything was fixed magically-ish.
I only found a file in /etc/webmin/postfix/ called version, which contains the Postfix version number, but I wouldn’t change that manually, at least until a dev has chimed in with any ideas… Sorry.
This post from Ilia seems to indicate that if you’re running a current version of Webmin (which is mandatory for this to work at all, anyway), you shouldn’t need to update the version file.
So, are you running current Webmin and Virtualmin versions?
It’s all fixed! I deleted /etc/webmin/postfix/version following a tip and after a restart the missing option appeared. Its great to see all the email for the domains working again. The correct version of postfix now appears in the dashboard. Thanks everyone.
