I thought I would attempt an in-place upgrade from CentOS 7.9 to Alma 8.7, using Alma Elevate.
This was eventually successfully completed except that ClamAV is not running and is missing from
Virtualmin > System Settings > Email Settings > Spam and Virus Scanning
I guess this is not wholly unexpected given it comes from EPEL repo. What is the best way to install ClamAV, and have it recognised by Virtualmin? I have tried
dnf install clamav clamd clamav-update
and get errors relating to missing libprelude
which I assume will also need to be installed, is that as simple as?
dnf install libprelude
I don’t want to go down a hole I can’t get out of.
[root@server1 ~]# dnf install clamav clamd clamav-update
Last metadata expiration check: 0:17:02 ago on Mon 13 Mar 2023 01:33:44 PM GMT.
Error:
Problem 1: conflicting requests
- nothing provides libjson-c.so.2()(64bit) needed by clamav-0.103.8-3.el7.x86_64
Problem 2: conflicting requests
- nothing provides libjson-c.so.2()(64bit) needed by clamav-update-0.103.8-3.el7.x86_64
Problem 3: package clamd-0.103.8-3.el7.x86_64 requires libprelude.so.28()(64bit), but none of the providers can be installed
- conflicting requests
- nothing provides libgnutls.so.28()(64bit) needed by libprelude-5.2.0-2.el7.x86_64
- nothing provides libgnutls.so.28(GNUTLS_1_4)(64bit) needed by libprelude-5.2.0-2.el7.x86_64
- nothing provides libgnutls.so.28(GNUTLS_2_10)(64bit) needed by libprelude-5.2.0-2.el7.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
