hi, the first selected mirror (mirror.1000mbps.com) in the install.sh script is offline. The installation fails on that problem. Is there a way to bypass this situatation? Can i probably choose my own mirror?
The install.sh script doesn’t select any mirrors, it simply uses “yum” to install packages. You may want to verify that in your yum repos, that the mirror you’re seeing there isn’t listed.
