I got mailman installed and 2 lists up and working, but the URLs in emails and such do not.
The email announces one of the list URLs as:
http://stnicholassaratoga.org/cgi-bin/mailman/listinfo/all
There is nothing in CGI, and when I find the actual page it is:
https://virtualminhostname.com:10000/virtualmin-mailman/listinfo.cgi/all?xnavigation=1
The fix button at the bottom says:
Virtualmin has detected that 1 virtual servers have mailman redirect URLs that do not match the Virtualmin base URL like https://stnicholassaratoga.org:10000. Click this button to correct them.
I don’t want it going to the webmin port at all, but to the first URL listed above.
I hit the button and Then I get:
Fixing Mailman URLs
Fixing virtual server stnicholassaratoga.org to use https://stnicholassaratoga.org:10000 …
… done
Applying web server configuration …
… not running!
Nginx is running, but I don’t have Apache installed - is the script not set to use Nginx?
Otherwise, how do I solve this problem?
