Mailman not starting?
Havent been here for a while couse couldnt get on DigitalOcean upgrade from 12.04 to 14.04.
Now i just made new server with 14.04 and updated then installed virtualmin.
Now i have new problem and it makes virtualmin not workable…
Steps i did 1h ago:
  1. On DigitalOcean made server with Ubuntu 14.04
  2. Installed updates and then virtualmin
  3. Made snapshot/backup image of clean installed server with virtualmin
  4. Started website:10000
  5. Did 1st time wizzard
  6. Got error
  7. Uploaded again snapshot
  8. Got same error.
  9. Cant get it away
  10. Google cant find solution
“Checking system” text has error in end:
Your system has 490.05 MB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the Postfix Mailserver module.
Apache is installed.
The following PHP versions are available : 5.5.9 (/usr/bin/php5-cgi)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and running.
Plugin AWstats reporting is installed OK.
The mailman queue processor /var/lib/mailman/bin/qrunner is not running on your system. It can be started in the Bootup and Shutdown module.
Mailman isnt started in Bootup and Shutdown module.
website:10000/init/edit_action.cgi?0+mailman
Trying to start Mailman:
Start Action
Executing /etc/init.d/mailman start …
  • Site list for mailman missing (looking for list named ‘mailman’).
  • Please create it; until then, mailman will refuse to start.
Trying to restart Mailman:
Reloading Action
Executing /etc/init.d/mailman reload …
  • Reloading Mailman master qrunner configuration
    PID unreadable in: /var/run/mailman/mailman.pid
    [Errno 2] No such file or directory: ‘/var/run/mailman/mailman.pid’
    Is qrunner even running?
    …done.
