Mailman logout after each click
example.com is the main domain of this server (hostname at install, PTR, MX, etc…)
subdomain1.com is a "Virtual Server" in Virtualmin/Webmin terms
Mailman Management Webinterface works for the main domain,
but at subdomain1 the mailman Administrator is thrown out at every
click, and needs to login again.
http://s3.example.com/mailman/listinfo/listone
Click at the bottom on Administrative interface
takes user to
https://s3.example.com:10000/virtualmin-mailman/unauthenticated/admin.cgi/listone
Subsequent clicks on Management etc, work
PROBLEM
On subdomain1 the mailman Admin is logged out at every click, and
It seems that there is some issue with cookies only written
for the main domain of the server, and not for the Virtual
or Sub Servers?
Anyone knows where to check for finding a reason for this symptome?
Thanks in advance, Robert
Post edited by: easytouch, at: 2008/04/12 04:10<br><br>Post edited by: easytouch, at: 2008/04/12 04:11
moin moin
Im afraid I do not know much about the mailman part.
However I recommend posting this in the support site as it sounds like an unwanted feature :slight_smile: .
http://www.virtualmin.com/bug-tracker/
